Aftermarket Keyless
Old Feb 18, 2005 | 01:09 PM
Gaaccord's Avatar
Gaaccord
Default Aftermarket Keyless
Ok i have done alot of searchin gon this site and others. My research is included so this becomes of value to others searching on this topic.
So my Question....
Where is a cheap place to get a good keyless entry system, i would love to have horn honk, light flash, dom light entry, and then just lock unlock features...
I have looked at ebay etc but circuit city has a basic code-alarm for 30ish and he shipping and handling often makes anything off the internet pricey. I am hoping yo gys have a "source".
Research so far....
Heres what i have. Most people just put an alarm on figruing the extra cost is worth it since our babies are so often lifted.... I am not worried about theft i think those car alarms that go off with sirens etc are really annoying and the lat one i had was very hard to adjust for sensativity and went off everyime the trains came by.
That said i have the following
ACCORD 1998-2002 WIRE COLORS LOCATION 12 VOLTS CONSTANT WHITE IGNITION SWITCH HARNESS IGNITION 1 BLACK/YELLOW IGNITION SWITCH HARNESS IGNITION 2 WHITE/BLACK IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 1 YELLOW IGNITION SWITCH HARNESS STARTER BLACK/WHITE IGNITION SWITCH HARNESS PARKING LIGHTS RED/BLACK ABOVE FUSE BOX DOME LIGHT BLACK/WHITE ( - ) PASSENGER SIDE PANEL POWER DOOR LOCK BLACK/BLUE ( - ) PASSENGER SIDE PANEL NEXT TO DOOR POWER DOOR UNLOCK ORANGE ( - ) LT. GREEN PLUG (TYPE B) TRUNK RELEASE WHITE/RED ( + ) DRIVERS KICK PANEL TACH SENSOR BLUE AT DIST BRAKE WHITE/BLACK ( + ) SWITCH ABOVE BRAKE PEDAL HORN GREEN/BLUE ( - ) GREEN 4 PIN PLUG PASSENGER SIDE FUSE BOX FACTORY DISARM BLUE ( - ) IN DRIVERS DOOR AT KEY SWITCH FACTORY ANTI-THEFT TRANSPONDER 791 REQUIRED
And i have pictures to show where these wires are thanks to the12volt.com...
So my Question....
Thanks in advance.
Brian
Old Feb 20, 2005 | 06:40 AM
streetfame01's Avatar
streetfame01
circuit city it would cost you no more than $150 and the install is good as long as you own your car
Old Feb 21, 2005 | 02:38 AM
dirtdiggler's Avatar
dirtdiggler
crutchfield.. their system has the harness you need . no cutting , just plug and play.
dirt diggler
Old Feb 21, 2005 | 10:53 AM
hype8912's Avatar
hype8912
Dr. Klaw
I saw one at autozone for like $35. I figured I'd just get an alarm with the lock and unlock feature.
Old Feb 23, 2005 | 09:27 AM
91ACCORDDX's Avatar
91ACCORDDX
I got mine at Autozone and it has options for all of those features. I installed mine entirely by myself and it took me about an 1-2 hrs. It only took that long because my car did not come equipped with power door locks so I had to mount and wire those also. But it is a good system and it is very easy to install. I just bought the keyless entry but they also had one with an alarm for like $15 more or something. I think I paid about $50 for mine. I believe the system I have is by Audiovox not quite sure though.
