Belt Noise
Old Feb 3, 2005 | 08:10 AM
flyromeo3's Avatar
flyromeo3
Default Belt Noise
hi guys.
Lately, but not so often when my car is idling say at a light I hear this noise similiar to when the power steering belt starts to whine or something.
I heard it again this morning after driving home from a cold start.
Temp outside was probably 25 degrees. I started up my car waited like 30 seconds then drove off.
I got to the traffic light and I could hear like a faint whine...
Is that an indication that the belts need to be tightened, replaced or could it escalate to a more serious problem?
Old Feb 3, 2005 | 09:31 AM
sophal's Avatar
sophal
Mr. Lover
pop your hood and check your belts and see if theres alot of play with them.. more than likely your sepentine belt is a little loose and just needs to be tighten.
Old Feb 3, 2005 | 09:39 AM
skabone69's Avatar
skabone69
:werd:
if they haven't been changed in a while you could always buy the belts and install them with the help of a buddy. it would take about 15minutes for the install, and the belts don't cost a lot.
Old Feb 3, 2005 | 10:15 AM
flyromeo3's Avatar
flyromeo3
my car has now 75,xxx miles....Belts never changed.
I plan on changing them all when i change my timing belt. Guess my plans will change.
