will this brake kit fit good on a accord?
Old Jan 31, 2005 | 11:27 PM
strykernyc's Avatar
strykernyc
Default will this brake kit fit good on a accord?
My friend is looking to buy this brake kit but we are not sure if they are going to fit good. what u guys think ?
here is the description from tas. btw he has 215/45/17 and drop n coilovers.
94-02 4cyl BIG BRAKE UPGRADE
Increase brake torque and reduce stopping distances with an Arospeed big brake upgrade kit. Kits includes 2 oversized slotted rotors, 4 piston calipers, performance brake pads, adatpers and hardware. Requires the use of 17" or larger wheels and may require the use of 10mm spacers depending on your wheel offset.
the solution if he gets a flat is to take off one of the rear tired and switch it to the front and use the spare n the back.
Old Feb 1, 2005 | 05:21 AM
JL95AccorD's Avatar
JL95AccorD
well he has the 17s that are required. He should just contact the seller and talk to them. It will definately work, It's just a matter of the offset that his rims have and if he will need to use the spacer they talk about. I have 18's on mine, I've been wanting to get that big brake upgrade, just a problem of the money. Those will definately look nice though. Post pics when he gets them on, and pics of the labor if he can do it himself. Does he have rotors on the back as well? BIg nice rotors in the front and some little ugly stock drums in the back might not look too hot. Go to a junk yard and get the complete setup and change the back to rotors if he hasn't got them already.
Old Feb 1, 2005 | 07:32 AM
Intrepid241's Avatar
Intrepid241
What he said is true. 17s are normally the min. rim size you can have. The problems start with the offset an such. In my opinion, there'd be less reason to worry with 18s. I think you should ask the seller as to fitment to be sure. Those brakes will look sick stuffed in 17s! If it all pans out, post pics!
