how do i wire reverse lights after manual converson???
Old Jan 27, 2005 | 09:15 PM
knight akkord's Avatar
knight akkord
Default how do i wire reverse lights after manual converson???
i tried to wire the yellow and green wire from the factory automatic harness into the two green and yellow wires that come out of the manual tranny, but my reverse lights do not work? do i need to do anything with the wires where the automatic shift knob used to be?
i've had it like this for like a yr. and it's starting to bug me when ppl can't tell that i'm backing out of a parking spot!
Old Jan 31, 2005 | 06:30 PM
knight akkord
no one knows??? where's all the pros at?
Old Jan 31, 2005 | 10:46 PM
hype8912's Avatar
hype8912
Dr. Klaw
If you are talking abouit the 94 accord for sale. Then their should be a Back-up light switch on the top of the transmission housing. It will have a Yellow wiring coming into it from the No. 1 fuse (Under-Dash Fuse Box). It will also have a Green/Black wire going out that goes to the reverse lights.
All this is in the 5th gen service manual on page 23-210 and 211.
Old Feb 2, 2005 | 08:43 AM
bonestock's Avatar
bonestock
on a 5th gen you extend the yellow and green/black wires from auto gear selector switch to the 2 wires on the reverse light switch on the tranny.
would probably also work if you extended the backup switch wires and tapped them into terminal g and h
Old Feb 3, 2005 | 07:22 PM
knight akkord
Wow now that is what i call directions! THanks dude! I owe u one!!!
Old Feb 4, 2005 | 01:44 AM
bonestock's Avatar
bonestock
no problem. i just recently wired up my reverse lights after not having them for almost a year after i did the tranny conversion
Old Feb 9, 2005 | 08:29 AM
UCF Accord's Avatar
UCF Accord
Former Member
how difficult is the tranny conversion? i've been thinking about it for when i do an engine swap.
