master cylinder fluid
Old Jan 25, 2005 | 07:50 PM
96exr's Avatar
96exr
Default master cylinder fluid
okay, my master clutch cylinder is leaking (i checked near teh clutch)
the actual container, in the top right hand side of teh engine bay....is pretty much close to empty, if not fully empty....
i know it says to fill up with either with DOT 3 OR DOT4....which one should I use?
does it make a difference?
what happens if i orginally had dot3 and now put dot 4? mixing the dot3 and dot4...does that do anything?
Old Jan 26, 2005 | 07:27 AM
JimBlake's Avatar
JimBlake
DOT 4 has higher boiling points than DOT3, but otherwise they mix OK with each other. DOT 5 is BAD. DOT 5.1 is sorta OK to mix with 3 & 4. Confused yet?
Clutch hydraulic system doesn't get as hot as brakes, unles you got a turbo sitting right next to the clutch slave. Use either DOT 3 or 4. But it's usually good to bleed enough fluid thru the system so it's all fresh. That takes care of the mixing worries.
Old Jan 26, 2005 | 11:28 AM
96exr's Avatar
96exr
does anybody have pictures or a detailed writeup on how to change teh master and slave?
Old Jan 28, 2005 | 07:52 AM
4thGen_Jonny's Avatar
4thGen_Jonny
Not CraZy, but a CarrIeR!
If it comes to it I will doc my replacement and write it up. Hope i dont have to do it though.
Old Jan 28, 2005 | 12:10 PM
96exr's Avatar
96exr
yes......please do the write up!!! and preferably pics
thanks in advanced so much
