Timing belt question - 5th gen
Old Jan 19, 2005 | 07:55 AM
Mike Oxbigger's Avatar
Mike Oxbigger
Default Timing belt question - 5th gen
Will I have to remove the strut/spring assembly and rotor/hub assembly on the drivers side to change the timing belt? its a 96 accord ex manual
Old Jan 20, 2005 | 12:44 AM
bob5114's Avatar
bob5114
Bob S Stein
No, Get a Helms manual for the detailed procedure. I just finished mine.
Old Jan 22, 2005 | 01:04 PM
Mike Oxbigger
how long did it take you bob?
is there anything special to know when changing out the seals?
what all came with your timing belt kit?
did you change out your tensioners?
Old Jan 22, 2005 | 07:01 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
Go to www.Helminc.com and first get the service manual for your year car.
Then order all the parts.
Water pump, tensioner, belts, etc.
I would also get the TSB cam seal kit from your local Honda serv. department if your car hasn't yet had the retrofit.
