Power window goes down but not up
Old Dec 22, 2004 | 06:45 PM
hondadriver22's Avatar
hondadriver22
Default Power window goes down but not up
You heard right. Do i need a new motor?
Old Dec 22, 2004 | 06:50 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Hmmm, did it slowly die, or sound like it was straining before.
I guess it could be the switch.
Do you have the autodown option? I'm guessing you do.... the autodown may be unhappy.
Does it click, click, click, after you use the autodown?
Old Dec 22, 2004 | 10:16 PM
strykernyc's Avatar
strykernyc
do you hear any type of noise when u press up? if u do then the cable is braking . is not the motor since it goes down.
Old Dec 22, 2004 | 10:19 PM
Skad's Avatar
Skad
Worst Poster Eva
mine does the same thing on the passenger side, except it's just the passenger that can't roll it up (they can roll it down) but I can roll it up on my side no prob..
it's kind of fickle, cuz sometimes it'll work for them..
Old Dec 22, 2004 | 10:25 PM
strykernyc's Avatar
strykernyc
sounds like a switch like bluetwo said.
Old Dec 22, 2004 | 10:34 PM
bonestock's Avatar
bonestock
can you go up even a little bit? like does it get stuck half way...?
it could also be that the glass got out of the tracks
Old Dec 23, 2004 | 05:33 AM
MarkPhx's Avatar
MarkPhx
We have a message board at work and someone just posted the same problem yesterday. This is what one of our co-workers had to say about it:
"This happened to me in my 2001 Sentra on the driver's window. It would go down, but not up. If I let the window sit for about 10 minutes and tried again, it would go up a half inch or so and then stop. Turned out it was a bad regulator that had to be replaced. I had it done under the Manufacter's warranty, so I couldn't tell you how much it cost to fix."
Hope that helps!!
Old Dec 23, 2004 | 01:41 PM
hondadriver22
ya that sounds right thanks
Old Dec 23, 2004 | 05:31 PM
mn__30's Avatar
mn__30
What year is your Accord?
Old Dec 27, 2004 | 10:52 AM
hondadriver22
