97 EX - Timing belt changed, strange noise coming from top end bearing/seal.
Hi everyone,
I had the timing belt, water pump, and oil seals changed on my 97 EX 2d 5-SPD the other day by a dealership. (92,000 miles) Now, there is a whining noise coming from the top end timing belt / cam / bearing / oil seal area. Now, it doesn't make this whining noise when the engine is cold. Only after the car has been driven for at least 5 minutes or so. This noise is locked in with engine RPMs, high revs = higher pitched whining or "zzzzziiiiiiii" sound. What's the deal? I've never had this problem with any of the other Honda's I've owned when the timing belt / water pump was changed. I've been taking it easy, allowing the pump, belts, and seals to 'break-in'. |
sounds like the tensioner is too tight. It makes the :"zzzzziiiiiiii" sound
Thanks
So, I should take the car back to them and get them to fix it, right?
