2000 honda ex help needed
Old Sep 6, 2004 | 02:35 PM
93AccordLX's Avatar
93AccordLX
Default 2000 honda ex help needed
Ok buddy has a car. Im not to fam with the honda's as i dont own one. I was thinking of helping him with just a few things. How is this. Upgrade plugs wires disttrub cap. Also cold air intake and k&N filter. My question is what plugs wires would you guys recommend ? Other than that any other free/safer mods that can be done ? sorry for such a newbie question.
Old Sep 6, 2004 | 02:41 PM
SmutWanter's Avatar
SmutWanter
"Made to Please"
Plugs and wires: NGK
Old Sep 6, 2004 | 09:29 PM
AcuraFanatic's Avatar
AcuraFanatic
To be honest with you, I've found that Honda's aren't a big fan of aftermarket ignition components unless you're running upgraded ignition. Go with OEM wires, NGK plugs will be fine.
Old Sep 7, 2004 | 02:50 AM
Intrepid241's Avatar
Intrepid241
Well I run Taylor 8mm wires and Bosch 4 plugs...you won't find many fans of this set up, but it works very well for me.
Old Sep 7, 2004 | 04:23 AM
93AccordLX's Avatar
93AccordLX
you guys have some web sites that have decent prices ?
Old Sep 7, 2004 | 04:39 AM
flyromeo3's Avatar
flyromeo3
Get your ordinary NGK and NGK spark plugs. ( 4cyl )
for 6cyl get the platnium plugs.
You sound a bit hesitant with helping him do the install.
If your not familiar with it or dont feel confident doing it. I would just take a step back and not do it.
One problem I usually encounter is removing the spark plugs. The sylicone thing that inserts into the spark plugs seems like it breaks off and I have to remove it with some long thin needle nose pliers.
To be on the safe side if you do help him just get a set of needle nose pliers just in case. Long ones that is.
