What are the Stock Camber settings for a 97 LX accord, do mine look right??
Old Jul 20, 2004 | 09:56 AM
joxur's Avatar
joxur
Default What are the Stock Camber settings for a 97 LX accord, do mine look right??
My car has intrak springs, 2.5" down, and I just had HPs put in with a camber adjuster next to the shock/frame mount. I got the alignment done but the readings came out like this
front left right
camber -1.4 & -1.3
toe -1/32 & 0
rear left right
camber -1.8 & -1.7
toe 1/32 & 1/32
Does this sound right? And also, my car seems lower now too, I scape on everything where as before I never scaped...HELP!
Old Jul 20, 2004 | 10:04 AM
A_D's Avatar
A_D
Reset?
i think you're supposed to have less than .5 degrees in the front
but in the back i think you can have up to .8 or 1 degree
as far as scraping, i can help you with that cause i'm slammed.
when you'er going over a speedbump or a ramp or something, always take it diagnaly, approaching the obstacle from the left and going over it in a diagnal/right angle
say that you're heading north and you come to a speedbump or a curb cut. you need to travel northeast over the obstacle.
that should clear it up.
Old Jul 23, 2004 | 11:34 AM
joxur's Avatar
joxur
What are your camber settings like? What kit are you using? Are your tires balding at all? Thanks!
