Secondary O2 sensor problem
Old Mar 4, 2004 | 03:42 PM
KiDFuZioN's Avatar
KiDFuZioN
Default Secondary O2 sensor problem
I am having a problem with my secondary O2 sensor. I took it to a shop and the guy there hooked up the OBDII scanner he had to my car but it didn't pull a code but the check engine light came on. On the OBDII scanner the Secondary O2 sensor said it was on but the voltage was 0 even after ideling the car for a long time and even after I drove it. What would cause the O2 reading to be 0 even though it said the sensor was on. Also what is the voltage supposed to be for the Primary O2 sensor. Using the SnapOn OBDII scanner the voltage was fluctuating between 2.90-3.10. By the way I have a 98 Accord Coupe with a converted manual tranny.
Old Mar 4, 2004 | 04:02 PM
RKV's Avatar
RKV
i have an o2 sensor i can sell you, i have a 98 accord, and i got a catalytic converter for sale as well, both are OEM, but both parts are off a 2000 accord
Old Mar 4, 2004 | 04:48 PM
KiDFuZioN's Avatar
KiDFuZioN
Well I don't know what the problem is so I don't want to buy it if I don't have to. Does anyone know what it could be.
Old Mar 4, 2004 | 05:35 PM
RKV's Avatar
RKV
my bad man, what i meant is, if u find out its a bad o2 sensor. it'll cost like $200+ new from honda, mines is good condition, i'll let it go for much cheaper, barely used.
Old Mar 5, 2004 | 06:08 AM
strykernyc's Avatar
strykernyc
from what i read about it but not 100% sure, u will end up changing ur o2 sensor either way u will have to change it soon or later if u havent, and the catalyst converted is most likely good cause what usually happens is if u drive the car for a longggg time with the 02 sensors bad then the catalyst converted will get fuk.
oem o2 sensors lifetime warranty from autozone goes under $200 for the most expensive one, and is soooo damn easy to change them i regret paying. but then again i am a noob
Old Mar 5, 2004 | 12:01 PM
KiDFuZioN's Avatar
KiDFuZioN
Does any one know what the voltage is supposed to be on the primary and seconadary O2 sensors?
Old Mar 5, 2004 | 01:25 PM
strykernyc's Avatar
strykernyc
output of the sensor is usually between 0 and 1.1 volts.
k too much info here and read all if u want to really understand and i am sure this is ur solution. here u go do the reading finally found something
http://tomasw.nailed.org/hem/modules...viewtopic&p=91
Old Mar 5, 2004 | 03:18 PM
KiDFuZioN's Avatar
KiDFuZioN
Do you know what it means if the voltage reading is between 2-5 volts? My primary O2 is reading between 2-3 volts under idle and jumps up when under load.
SuperDave
92+ Civic/EL & Del Sol
Aug 21, 2003 08:32 AM
Integrafanatic
5
Jun 28, 2003 06:28 PM
Ryleeryno
Engine Swaps, Tech & Tuning
5
Mar 23, 2003 10:43 PM
Ryleeryno
Accord
3
Mar 23, 2003 09:00 PM
