noise from turning wheel
Old Jul 30, 2002 | 04:14 AM
WHITEPEARL ACC's Avatar
WHITEPEARL ACC
Default noise from turning wheel
when i was parking, i keep hearing a noise when i turn my steering all the way to the left. The noise is a straining sound. it does it at the last 1/4 turn to the left...what is wrong?
Old Jul 30, 2002 | 04:47 AM
GimpyAccord's Avatar
GimpyAccord
Default Re: noise from turning wheel
was it like a moan?
check your power steering fluid. if its fine then i'd guess your powersteering pump is on its way.
Old Jul 30, 2002 | 05:03 AM
WHITEPEARL ACC
how much is to replace that pump...and it is only whn turning to the left..
Old Jul 30, 2002 | 05:55 AM
GimpyAccord
dunno! when mine went bad i cut the belt, removed the pump and looped the rack back to itself. i imagine a couple bills at most.
<--- ghetto.
Old Jul 30, 2002 | 06:38 AM
JonHsiung's Avatar
JonHsiung
u c l a
mine has more of a metal creaking sound sometimes on some turns. i think it's due to the fact that i got in an accident before and had to have it fixed. maybe because the car's lowered. *shrug*
Old Jul 30, 2002 | 06:40 AM
WHITEPEARL ACC
my car is lowered as well, will double check on friday with mechanic..
Old Jul 30, 2002 | 11:35 AM
AccordVTEC's Avatar
AccordVTEC
Wannabe M0DERAT0R
If its a squealling(sp?) sound then check the belt. I had some AEM pullies and it was making noise bc the belt was loose. If it's more of a clunk clunk noise when you turn, check the CV joints... they may be bad.
Old Aug 17, 2002 | 07:57 PM
Hepcat's Avatar
Hepcat
it could also be the bearings that are going bad, just a thought
Old Aug 17, 2002 | 10:50 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
the pump tends to strain when the wheel reaches it limit because the pump cant pump the fluid anywhere anymore because the rack is at its limit... just dont turn the wheel so far... but it dosent hurt to check things either.
Old Aug 18, 2002 | 04:51 AM
LxAccord97's Avatar
LxAccord97
do u hear the noise only when u turn the steering wheel to park or when u drive too
