door removel
Old Jan 9, 2004 | 04:04 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Default door removel
I wanted to remove my driver side door. Before I do this are there any special tools I need and which bolts would I need to remove. I dont have an Helms mannual, and I should get one but any help/Tip's would much be appreciated.
The reason why is the door is sticking like a mofo. I have to Push will almost all my weight into the door to get it open.
Bruce
Old Jan 10, 2004 | 07:22 PM
onebadrs's Avatar
onebadrs
Default accord doors
don't you have a warranty to the accord?? the dealership should be able to fix this regardless at a low price
Old Jan 10, 2004 | 07:38 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
Sounds like the hindge not the inner door at all.
Do you know how to adjust it?
Old Jan 10, 2004 | 08:37 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
I got 45k on my car no warrenty.
I been looking at it and its the weather stripping that is making it hard to open...
When i do shut the door i can see that door will lift 2cm higher. Any pictures of what bolts to remove? I only see 1 bolt to remove and any other advice?
Old Jan 11, 2004 | 09:25 AM
MrChad's Avatar
MrChad
You have a hinge issue.
Your door has fallen on the hinge, you need to raise the door up where the door meats the A-piller/firewall jam.
There are directions for this in the dealer manual.
www.helminc.com
Old Jan 12, 2004 | 12:20 AM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
sounds like an easy task.. thanks MrChad
