6th gen engine hesitation
Old Dec 26, 2003 | 03:29 AM
blurr
Guest
Posts: n/a
Default 6th gen engine hesitation
the problem: during acceleration at one point or another the engine will start cutting off and on causing major hesitation and jerking.. not subtle either.. i'm talking about literally gassing it and it'll feel like you took your foot completely off the gas then punched it again.
the engine light finally came on and the code threw out 'v-tec solenoid' problem.. but the problem is that we tested it and it's fine... another major problem is that the occurrence is sparatic so i can go to the dealer and try to show them, but it might never happen for that day or that moment.
so has anyone else experienced this problem before? comments? suggestions?
Old Dec 26, 2003 | 04:50 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
is it automatic
if it is it could be a tranny issue
Old Dec 26, 2003 | 04:03 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Originally posted by PikkaGTR
is it automatic
What Year and is it a V6 or I4?
Old Dec 26, 2003 | 06:40 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
is it like a sputtering noise when u get above say 4k?
Old Dec 26, 2003 | 10:39 PM
blurr
Guest
Posts: n/a
99 Accord 4cyl. 5spd sedan...
it's definately not a tranny issue, and it's not noise. the car literally cuts off power, then kicks in...
think of it as driving and while you're acclerating, popping the clutch in and out.
the factors we're looking at are: ignition problem, vtec problem (but could be related to the last one), one of the several sensors is messed up..
Old Dec 27, 2003 | 05:33 AM
vassil3427's Avatar
vassil3427
Have you tried replacing your spark plug wires? Distributer cap and button?
Old Dec 27, 2003 | 03:16 PM
blurr
Guest
Posts: n/a
button?
actually, this always happened. it happened from the time i bought the car new. it was just that it would happen once, then it wouldn't happen again for several months. that's why the dealer could never find the problem. it's just now that it's happening a lot more often so it's becoming annoying.
the cap and rotor have been replaced. the spark plugs was changed about 2k miles ago... we dismantled everything and checked for burnt spots, misfires.. it's all fine.
Old Dec 27, 2003 | 03:46 PM
bad alternator gives the same results. how's your electical system when the problem starts?
also, does your car spudder or stall when at complete stops?
Old Dec 27, 2003 | 05:24 PM
AcuraFanatic's Avatar
AcuraFanatic
Originally posted by blurr
button?
Check your power control module.
Old Dec 28, 2003 | 07:38 AM
DriftKing's Avatar
DriftKing
fuel pump? ground points?
