replacing rear wheel bearing 93 accord
has anybody replaced a rear wheel bearing on an accord with rear disc brakes, hub over rotor design(that should be all 4th and 5th gen accord EX's)? do you buy the whole hub assembly and have the rotor pressed on?
Older Honda Fanatic
you buy the whole hub/bearing assembly already pressed together. I think they're like $65 from autozone.
Actually, on the rear, it is rotor over hub... (yes, opposite the front) so its really easy to change...
