crazy right turn signal
Old Nov 25, 2003 | 09:34 AM
BobCarter's Avatar
BobCarter
Default crazy right turn signal
What would cause my right turn signal to blink crazy fast? All the bulbs are good.
Old Nov 25, 2003 | 09:49 AM
jschmid's Avatar
jschmid
Check the other signal bulbs. For example, no front signal will give you a "hyper" rear signal.
Old Nov 25, 2003 | 10:17 AM
AngryNerdRock's Avatar
AngryNerdRock
this space for rent
i have that too....i put in a new bulb on my driver's side front signal and still the same thing. it doesn't turn on at all, but my sidemarkers and rear taillights blink fast. it's weird too cuz last night, it was blinking slow and it actually blinked on the front also, but still wouldn't stay on when my lights were just on
Old Nov 25, 2003 | 11:35 AM
A_D's Avatar
A_D
Reset?
check fuses
if you put a fuse in with less amperage than called for it'll do that i beleive
Old Nov 25, 2003 | 12:55 PM
Accord1278's Avatar
Accord1278
first check the bulbs...front and back... if the bulbs are ok, then check the relay...sometimes the relay will go bad. my cousin had a relay problem on his Acura....all we did was tap it a few times and it fixed itself :thumbup:
Old Nov 25, 2003 | 02:53 PM
praxis's Avatar
praxis
Yeah check relays and flashers (fuse thing).
