radio code
Old Nov 24, 2003 | 07:26 PM
eNoble's Avatar
eNoble
My Accord Drives Smooth.
Default radio code
I have a 93 honda accord, used. After hours of trying to get to the radio I finally get it out. Well the reason I was getting it out is because I was wanting to see if the wires were hooked up right because the sound would not fade to the front or back. Well I unhook it now I hook it back up and it displays code, then I turned the car off turn of the the radio, then turn the car back on and it displays 2code. Well were do I get a code and how do I enter the code. Is there a special process?
Thanks
PS if anyone has got a wire diagram showing wich wire color goes where that would be great too.
Old Nov 24, 2003 | 07:42 PM
vassil3427's Avatar
vassil3427
There shouldnt be any special process, you'll have to probably take the radio in with you to a honda dealership and they'll run the serial number on it and give you the code. You can try calling, but normally they want you to come in with proof you own the car.
Old Nov 24, 2003 | 07:57 PM
eNoble's Avatar
eNoble
Does anyone know any codes to give me or do you have to have an exact code?
Old Nov 24, 2003 | 08:23 PM
vassil3427's Avatar
vassil3427
No it has a special code deciphered from the serial number...
