17"s VS 18"s wheel
Old Nov 17, 2003 | 09:07 PM
HAZE's Avatar
HAZE
Just Hazin'
Default 17"s VS 18"s wheel
Right now i have 17"s that weigh 26 lbs... If i upgraded to some rota 18"s that weighed 18lbs, would i gain acceleration, or lose some because of that extra inch?? LMK what u guys think...17s look way too small on my accord.
Old Nov 17, 2003 | 09:15 PM
AwSoMNaMjA's Avatar
AwSoMNaMjA
extra inch doesnt matter...since the tire will get smaller....it wont matter since the whole tire diameter will be the same...more rim...less tire...
Old Nov 17, 2003 | 09:20 PM
HAZE's Avatar
HAZE
Just Hazin'
well, ive heard that one pound on each wheels is like 100lbs onto your car, so would i actually gain speed?
Old Nov 17, 2003 | 09:27 PM
AcCoRd97Lx's Avatar
AcCoRd97Lx
Jordan ModaratOr
i want 18s and i have 17s
Old Nov 17, 2003 | 09:43 PM
93accord4door's Avatar
93accord4door
upgraded to 97 ;]
i want 18s too
Old Nov 17, 2003 | 09:45 PM
polakatl's Avatar
polakatl
the smaller ur overall diamater (wheel+tire) the faster u will accelarate. When I put on my 16's with low profiles for auto-x the car is really FAST and the gears become closer together. If u get the lighter 18's with a low profile tire (see my sig) then u will have a diamater really close to stock. With the lighter wheel u should be faster. Get the 18's anywayz couse they look better on accords.
Old Nov 17, 2003 | 09:59 PM
jschmid's Avatar
jschmid
It's not quite that much.
One source: "The use of light-weight alloys in wheels reduces rotational mass. This means that less energy will be required to accelerate the wheel. Given that each pound of rotational mass lost provides an equivalent performance gain as a 10 pound reduction in vehicle weight, the benefits of light alloy wheels on vehicle performance cannot be overlooked.
For example:
A reduction in the weight of the rim/tire assembly of 5lbs x 4 (all around the car) is equivalent to a 200lb weight reduction in vehicle weight (thats worth 0.200 in the 1/4 mile)"
If you are really into increasing accleration, get 16's.
If you want the looks of 18s, just get them. Some lightweight 18's won't slow you down any more than those 17s. 26lbs for 17" is pretty heavy.
Also, as tire sidewall gets shorter, it generally gets thicker and heavier. even though an 18" tire has less sidewall, it's likely significantly heavier than a stock 15" tire (some due to wider width too).
Old Nov 17, 2003 | 10:57 PM
HAZE's Avatar
HAZE
Just Hazin'
hmm..i was planning on getting some 215/45/18 tires with it for daily driving.....actually, Jschmid, i was planning to get the subzeros in 18s like i think u have...how much acceleration u lose over stock? LMK
HAZE's Avatar
HAZE
Just Hazin'
my bad, thats 215/40/18
