tire width
Old Nov 12, 2003 | 11:23 AM
grimskunk's Avatar
grimskunk
Default tire width
If I'm currently using my stock wheels.. 185/65-15s, could I put 205/60-15s tires on them without problems? (I can't afford new rims..)
How would this affect performance? How does tire width affect performance overall? I know it can reduce handling on corners and in the snow, but otherwise, I have no clue.
Old Nov 12, 2003 | 11:29 AM
LX4CYL's Avatar
LX4CYL
Cone Basher
Do you have a 98-02 4cyl?
http://www.miata.net/garage/tirecalc.html
I want to put 215/60-15 Sumitomo HTR-200s on my stock 15" steelies and use them for autocrosses, so I don't have to shred my expensive 18" Yokohamas.
Will the wider tires help performance, and will they fit on the stock '02 LX I4 steelies? Are the stock steelies 6.5" wide?
Old Nov 12, 2003 | 12:17 PM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
sounds like he has a 96 or 97 LX. in that case either 195 60 15s or 205 55 15s will work, with 205 55 15s being the best choice for performance.
Old Nov 12, 2003 | 01:22 PM
grimskunk's Avatar
grimskunk
Ya, I have a 97LX 4cyl
Will both 205/60-15s and 205/55-15s fit on my stock rims?
Old Nov 12, 2003 | 02:42 PM
92lx
Guest
Posts: n/a
205/55 will fit quite fine. 205/60s will be a bit "taller".
- Nathan
Old Nov 12, 2003 | 02:53 PM
AccordSleeper
205 55 >195 60>205 60 for a 90-97 accord
a 205 60 15 will have a taller sidewall than a 195 60 15, making it flex more and handle worse. the sidewall number "60" is 60% of the width, thus as the width gets wider and the aspect ratio stay the same the tire gets taller. which is why 205 55 15 fits perfectly.
Old Nov 12, 2003 | 02:58 PM
grimskunk's Avatar
grimskunk
Won't the 205/55s adversely affect my speedometer, moreso than the 205/60s? I think the 205/55s have 2.4% difference, whereas the 205/60s have about a 1%
Old Nov 12, 2003 | 09:31 PM
AccordManiac's Avatar
AccordManiac
Korean Member
I have 205/55-15 on my 93 Accord 10th Anniv. and ride is smooth and more grip to the road..
But one of my friend that has 205/60-15 on 96 Accord EX and ride is little bouncy..
I would recommend 205/55-15..
Old Nov 13, 2003 | 04:31 AM
AccordSleeper
as long as it's under 3% your fine. besides your main concern is handling here and 205 60s aren't the right choice here.
Old Nov 13, 2003 | 05:08 AM
grimskunk's Avatar
grimskunk
Makes sense, thanks
