changing driver's side headlight (2000)
Old Nov 11, 2003 | 03:47 PM
Farjamed's Avatar
Farjamed
Default changing driver's side headlight (2000)
i am trying to change the headlights in my car. one went out yesterday and i got replacements that are a little different in color and brightness. i changed the one on the passenger's side with no problem, but the one on the driver's side wont come out. i took off that cover, and have tried to remove it but it seems really stuck in there. do i have to take anything else out to remove the bulb? thanks
Old Nov 11, 2003 | 07:52 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
should be the same as passanger except it has less space to put your hands in there
Old Nov 12, 2003 | 05:53 AM
if it's really stuck ... there are 3 screws you can loosen to remove the bulb too. just take a look to see what the bulb is holding onto.
Old Nov 12, 2003 | 03:34 PM
Intrepid241's Avatar
Intrepid241
I replaced my headlights with Sylvania Silverstars, right side was easy but the left was a tight fit. But It came out, just not easy to manuver your hands in the small space
