Is their a reason im going through coolent so quick?
Old Nov 10, 2003 | 12:18 PM
96JdmAccord's Avatar
96JdmAccord
Im So JDM
Default Is their a reason im going through coolent so quick?
Im not leaking. But I keep having to refill it ever week? This is radiator coolent too.
-Jon-
Old Nov 10, 2003 | 12:58 PM
jdmaccord6's Avatar
jdmaccord6
From: Chi-town but going to school at PURDUE UNIVERSITY
did u blow your head gasket? i went through radiator fluid like crazy on my supra because i blew the head gasket....twice...
Old Nov 10, 2003 | 02:05 PM
planenut's Avatar
planenut
you may be leaking and the coolant is evaporating on the hot engine before it hits the ground, or, you blew the head gasket. check hte oil for signs of water contamination, if none, get the car nice and hot and do a thorough leak check under the hood, take a good look at the water pump weep hole and your hoses, including the heater hoses.
Old Nov 10, 2003 | 11:41 PM
96JdmAccord
Im So JDM
head gasket? What would be the signs of that? Thanks guys...
Old Nov 10, 2003 | 11:57 PM
whoaitslen2's Avatar
whoaitslen2
hermit
headgasket- when you change your oil and you see your oil is mixed with coolant... usually brownish color.
radiator cap- check to see if its not broken and check for coolant stains around that area and above the fan.
hoses- check around with a flashlight for any cracks or holes, anyplace coolant would leak out
Old Nov 10, 2003 | 11:59 PM
jdmaccord6's Avatar
jdmaccord6
i forgot the color, but i think if your exhaust smoke is whiter then normal then it is a blown head gasket....you might want to go ask a local autoparts store just to make sure.
Old Nov 11, 2003 | 03:54 AM
Bl@ck's Avatar
Bl@ck
Sinner
or you can check your coolant for oil... if the head gasket is blown, the leak isn't just in one direction.
Old Nov 11, 2003 | 12:55 PM
MaCeCL's Avatar
MaCeCL
[]D [] []V[] []D
if u dont see any on the ground its def the head gasket .. blew one on my truck and the same thing happend u better get it before u blow the whole engine
