Food for thought... 2point6's dyno 11/4/03
This is in my 1990 Accord 4dr.
Very much thanks goes to Mike! =) Awsome job man!
12/1 comp on 91 octane.
Fuel ratios were very good 12.8- 13.4 across the board.
Engine Block: '93 H22a "bored and stroked" to 2.44ltrs of displacement built by Collective Racing. Custom 98mm crank (Balanced and nitrited), Darton sleeves, Crower Pro-billet rods, Custom 12/1 compression 89mm JE pistons, Prodrive oil pump, Unorthodox Racing crank pulley, manual timing belt tensioner conversion.
Cylinder head: Ported and polished by Collective Racing, Web Cams custom camshafts, Web Cams springs and Titainium retainers, Euro Type R manifold conversion, Hondata intake manifold gasket, Erick's Racing 70-68mm Throttle body, RC engineering 440cc Fuel injectors, B&M fuel pressure riser and Guage, STR cam seal, AEM cam gears, SMSP 4-2-1 header (prototype #3), ARP head studs, ARP main studs, Cometic head gasket.
Originally posted by 96JdmAccord
That is really awesome. I am extremely suprised with those numbers. When do you shift at? i would take it you would around 9k. Awesome man! One way to build a good motor!:thumbup:
Jon
Jon
