Problem with idleing
Old Nov 3, 2003 | 08:16 PM
AccordManiac's Avatar
AccordManiac
Korean Member
Default Problem with idleing
I have problem with idleing.
Last saturay day moring.. I warmed up the car..
and drove like 3min.. Check engine light and
D4 was blanking.. So I turn off the engine and
Turned back on. No lights.. everything was ok.
Same day afternoon ..
I drove the car around the block and it was fine..
This morning (Tuesday)
I had hard time starting up the car.
It took me 4 tries.. with presssing the gas padle to
keep the engine going..
After that while going to detailing shop...
check engine light came on and so I restart up the car again..
No more check light, but idle will not drop
below 1,000.. (1,200 to 1,300)
What could be wrong?
Far as I know.
Check light = O2 sensor
D4 blanking = TCU
Mileage = 170K
- Valve adjustment has been done (last month)
- Replaced Fuel filter (last month)
Thanks for reading.
Old Nov 4, 2003 | 12:08 AM
AccordManiac
Korean Member
Anyone?
Old Nov 5, 2003 | 05:58 PM
AccordManiac
Korean Member
Problem solved.
ECU Error code..
ECU #6 - 6 blinks (Thermostat error)
A/T #10 - 1 long blinks (Thermostat error)
Broken thermostat was sending Cold engine signal
to ECU idleing and rpm would drop..
F22A engine has total of three thermostat..
One I had problem was located at engine block..
Paid $25 for used 97 Accord Thermostate.
