Headlight removal
Old Oct 24, 2003 | 10:43 PM
Weiman's Avatar
Weiman
Default Headlight removal
anyone have any links on how to remove your headlights.
Old Oct 24, 2003 | 10:53 PM
ODUB's Avatar
ODUB
Banned
no links but i can tell u it's pretty damn easy lol just remove the six clips and 4 bolts on the bumper, take it off, then remove the 4 bolts on the headlight...done
Old Oct 24, 2003 | 10:57 PM
Weiman's Avatar
Weiman
do i just have to remove the cover of the bumper?
Old Oct 24, 2003 | 11:29 PM
99Accolude's Avatar
99Accolude
heavy cars Rule!
You need to remove to the whole bumper. then theres like 4 bolts on the light. one on the top. (need to open the hood) theres one in the right side after you take off the bumper then theres 2 hidden just follow the metal bracket you should see all of them.
Old Oct 25, 2003 | 07:06 AM
Oxygen795's Avatar
Oxygen795
here, ill help you :
Step 1... open hood and take out front grill (makes it easier i think....)
Step 2... remove 2 screws from the side fenders in the wheel well 3/4 way front the bottom should be facing straigt up toward the sky... metal screw not plastic pop off one....ones that is off there is another screw few inches inside fender from that one...take that out too
step 3... remove bumper lights...if u have never done this before its pretty u need a fairly long screw driver...there should be 2 holes on the inside of the bumper get a flash light and shine it in...u should see the screw...just unscrew it and it should come right out...then disconect light....anyway back to bumper removal...
Step 4...inside bumper hole there should be 2 bolts on each side....the ones ont eh right (facing the car) are the hardest to use...i recomend a very large extension....all the bolts inside here are 12mm
(sorry hard to see)
Step 5... remove 4 bolts underneath front bumper...there pretty easy to find....these are 10mm (might be 11 i forget)
Step 6... this should be all u need to remove the bumper....jimmy it a litte and it should come right off
Step7...Removing old headlights...there is 5 bolts for each headlight (not sure with mm might be 10,11, or 12) there is to above and 2 below and one on the side....i recomend removing corners....(if u have never done that before its easy remove the 1 screw about the headlight and then pull lens toward u its kinda tough but just keep pulling)
Step 8...install new headlights...(it the same as removing the old ones hehe just in reverse....make sure they work 100% before going on
Step 9... Put the bumper back on.... not hard again same as taking off but in reverse....hehe
Step 10... put all remainging peices together and then step back and stare
Step 11...wait till its dark...if not already...then find a nice dark wall the aim lights at...adjust accordingly...
Old Oct 25, 2003 | 12:04 PM
K43L1n's Avatar
K43L1n
so how exaclty do you aim your headlights..i have never done that before...my talon was easy becasue on both headlights it had a level meter in them. thanks
Old Oct 25, 2003 | 12:43 PM
Oxygen795's Avatar
Oxygen795
just by losing the actual bolts for the headlight, and you can slide the headlight assembly around, thats what i did for mine at least and it worked good for me
Old Nov 7, 2003 | 02:19 PM
groovedaddy's Avatar
groovedaddy
Any instructions for a 97? Or is ti pretty much the same?
Old Nov 7, 2003 | 02:21 PM
Oxygen795's Avatar
Oxygen795
same
Old Nov 8, 2003 | 04:51 PM
imfastidious's Avatar
imfastidious
yes.....same bolts
