Maintainence Required Light
Old Oct 13, 2003 | 12:37 PM
eminem's Avatar
eminem
Default Maintainence Required Light
How do you get rid of that light? It came on around 11k miles I think.. I've got everything set on the car just need to get rid of that damn yellow light that reads " Maintain Req'd"
Edit: Forgot to mention that it's a 2002 Accord LX Sedan
Old Oct 13, 2003 | 02:14 PM
jschmid's Avatar
jschmid
Check your owners manual, it has directions. Something like pushing in the trip odometer reset button while turning car to "on" position until the light stops flashing - something like that I think.
Old Oct 13, 2003 | 03:11 PM
eminem's Avatar
eminem
i think i lost the owners manual, but ill check.. and also try that thanks!
Old Oct 13, 2003 | 03:12 PM
Weiman's Avatar
Weiman
all u do is push the button next to it with ur key, its like a slit..
Old Oct 13, 2003 | 03:53 PM
jschmid's Avatar
jschmid
For yours, yes. His is a a 6th gen, it's different.
Old Oct 14, 2003 | 06:29 PM
LelandHendrix's Avatar
LelandHendrix
Just thought I'd pass this along as some gee whiz:
I just read on another forum that for the 7th gen, you turn the key all the way to on (not crank) and when all the lights are on, push the dimmer switch in and hold it for 10 seconds. The light should go off at that point.
Old Oct 15, 2003 | 12:44 PM
MeiSoSlow's Avatar
MeiSoSlow
WEEEEE!!!!!
lol, what you do is with the car off, hold down the reset button on the dash cluster. Then turn the ignition to the #2 position or the on position and leave it there. After a couple seconds the MR right will blink then blink off.
Old Oct 16, 2003 | 03:41 PM
dreman's Avatar
dreman
MeiSoSlow
you are the bomb, I had that same light on for about 2weeks. I got my Oil and filter changed last night and when i got home from the shop I tired your method and it worked just like you said. I have just hit 40K on my accord what is the most common reason it came on?
Old Oct 19, 2003 | 12:21 PM
MeiSoSlow's Avatar
MeiSoSlow
WEEEEE!!!!!
The mr light is more like a oil change reminder. ECU just turns the light on after a certain amt of miles to remind you to do the standard maint.
Old Oct 19, 2003 | 03:51 PM
Kingseth2's Avatar
Kingseth2
Every 7500 miles. The light means absolutly nothing.
