i need help guys
Old Oct 6, 2003 | 11:33 AM
bustah49's Avatar
bustah49
Mr. Motorhead
Default i need help guys
i just took the cam out of my car and did a compresson check. did it this way to see if any valves were bent. 1st cyl 58lbs
2nd 26 3rd25 4th 25....tells me that something seriuosly wrong...right? so i decided to pull the head off, 45minutes later i check the head....i do the wd40 down in the head trick to see if any leaks through to the combustion side...and guess what...NO LEAKS.could i still have bad valves? there is no indication that the valves hit the pistons.i am lost...please help? it is a 97 civic dx with 74,800 miles on it.
Old Oct 6, 2003 | 11:44 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
how did you do the compression test? You may have done it totally wrong....
Old Oct 6, 2003 | 11:46 AM
bustah49's Avatar
bustah49
Mr. Motorhead
with my compression tester.you know the kind where you pull the plugs out and screw the hose inplug hole...turn it over...
Old Oct 6, 2003 | 11:50 AM
bustah49's Avatar
bustah49
Mr. Motorhead
any 1? this is not my first time with a wrench in my hand...no and i did not just fall off of the turnip truck....or got trowed off the banana boat...just a good ole redneck mechanic looking for suggestions
westcoaststyle
ok, you did turn it over by trying to start the car then?
this is the one that was eating oil right?
I think it could be your rings... that's my first thought...
Old Oct 6, 2003 | 11:52 AM
illicon2003's Avatar
illicon2003
I think if you bash your head with a baseball bat a couple of times that the valves will fall back into place,,,,,,,,,,,,,,they are out of alignment
Old Oct 6, 2003 | 11:54 AM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
:slap:
Old Oct 6, 2003 | 11:55 AM
bustah49's Avatar
bustah49
Mr. Motorhead
ok....this is not the 1 burning oil...i started it after letting it sit for a week...it shut off. when i tried to restart it..it turned over like it had no plugs in it.up till that point....it never used a drop of oil...ran perfect..
Old Oct 6, 2003 | 11:58 PM
bustah49's Avatar
bustah49
Mr. Motorhead
ttt
