B series rods on D series crank
I just noticed that the D15B7 con. rod is 134mm in length compared to the D16 motors which are 137mm. By using D16 rods and pistons would increase the displacement.. correct me if I'm wrong. But also noticed that the USDM B16A2 uses a 134mm con. rod unlike the B18B's 137mm or B18C's 137.9mm. Will the B16 rod bolt up to the D-series crank?
check out www.d-series.org
It can help a lot with shit like this. But from what I ahve read, yes it will work if you notch the block. The only problem being the pistons. The wrist pins on the D's are a different size. |
Re: B series rods on D series crank
Originally posted by mrdx I just noticed that the D15B7 con. rod is 134mm in length compared to the D16 motors which are 137mm. By using D16 rods and pistons would increase the displacement.. correct me if I'm wrong. According to the specs on Crower's website, the D16 rods won't fit onto the D15B crank anyway. |
use LS rods. you will have to modify them though. PM Mantis.
