obdII to obdI
If I'm going to put the b18c5 motor into my 95 civic ex. what would I have to change out to make it work? If my existing ecu and other misc. component are OBDI....If I used the distibutor,ecu,harness and all sensors off of a OBDI car, wouldn't I still need to upgrade to OBDII ???
EVERYTHING on the motor will be OBD2, even the distributor.
Then you just plug in an OBD1 ECU and go. It's simple. :) |
what would have to be done to my p28 to run a b18c5 type r motor?? who could reprogram it for me??
if you get the motor with the engine harness, it will plug into your car fine. you just need to get you p28 chipped to stock b18c5 specs. try www.jdmhondaparts.com i hear katman does good work.
engine wire harness
i am in the planning stages of a similar project: '94 civic ex sedan. B18c5 engine swap. was i mis informed that the the engine wire harness on a jdm b18c5 will ned to be replaced 'coz of it being a right hand drive? it will help some if i do not need a usdm engine wire harness. i need some clarification. :confused:
