tein ss height adjustment
Old Sep 28, 2003 | 04:56 PM
jordan88's Avatar
jordan88
Default tein ss height adjustment
hi, since i have my tein ss installed already, now i want to raise it, do i need to remove the wheels and the whole suspension to adjust the height?
how do i measure it to be sure 4 corners are at equal height?
thx
Old Sep 28, 2003 | 04:59 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Just jack it up. To measure either use a tape measure or just count how many little ridges you go up.
Old Sep 28, 2003 | 05:07 PM
jordan88's Avatar
jordan88
by the way, should i level all 4 corners or have the front slightly higher than rear or rear higher than front?
thx
Old Sep 28, 2003 | 05:08 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
I just lower it to where it looks good. If you are going to race i would test out the heights.
Old Sep 28, 2003 | 05:11 PM
jordan88's Avatar
jordan88
also, i have subs in my trunk too, which it lowered my rear abit, should i take out my subs b4 adjusting my ride height?
thx
Old Sep 28, 2003 | 05:13 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
No it will be fine, but it may make the rear settle lower.
Old Sep 28, 2003 | 05:18 PM
jordan88's Avatar
jordan88
by the way, is it ok for a suspension to have a difference of 1-2mm? cuz its really hard to have exact height on these coilovers
thx
Old Sep 28, 2003 | 05:54 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
It will be ok.
Old Sep 28, 2003 | 06:07 PM
jordan88's Avatar
jordan88
also, what is a good height and setting for lowering less than 1.8"?
what is the best setting to set the damper stiffer level? i want to be able to have good control and handling.
should i set the rear damper's stiffer level to be abit more than the front ,
and would having 4 corners at the same height provides better traction and control?
thx
Old Sep 28, 2003 | 06:44 PM
jordan88's Avatar
jordan88
hi, i also want to know what are those spring rate mean, the front and rear have differrent spring rates. is it the higher the spring rate the stiffer it is? but i thought we use the damper to control the stiff of the car.
thx
