Removing Rear Speakers in 2000 civic
Old Sep 24, 2003 | 06:32 PM
Dupes's Avatar
Dupes
Default Removing Rear Speakers in 2000 civic
I am in desperation mode right now and dont know how to take the speakers out...i tried to pop the cover off but i dont think that is the right way to do it because it is extremely hard...i would appreciate any help that you fellow members can provide...Thanks a Ton
Old Sep 24, 2003 | 09:05 PM
next157's Avatar
next157
you have to take out your rear seats, take off your rear side panels, so that u can take the top panel where the speakers are mounted. Thats how i did it. Its time consuming, but i think its the only way. If anyone knows a better and easier way, suggest it. Good luck.
Old Sep 25, 2003 | 06:27 AM
Rex'in'Efex's Avatar
Rex'in'Efex
I used to work at a stereo shop.... and yup it sucks but that is the only way to do it.
Old Sep 25, 2003 | 06:30 AM
str8edgexx's Avatar
str8edgexx
on a 2000 civic, you do not have to take the rear seats out...you only have to do that on the 7th gens. You need to pop the back deck cover off. Its pretty easy. All you have to do is grab some needle nose pliers and squeeze the clips from the bottom (in the trunk itself) and then push them upward. Once you do this to all of the clips, the deck will pop up, and you'll have access to the speakers.
Old Sep 25, 2003 | 04:39 PM
Dupes's Avatar
Dupes
Thanks a ton...that last one seems like it will def work and is much easier
Old Sep 25, 2003 | 09:42 PM
str8edgexx's Avatar
str8edgexx
let me know how it turns out
Old Sep 25, 2003 | 09:55 PM
Nelson's Avatar
Nelson
Administrator
Wow, that seems like a b*tch if I had to do all that to take out speakers
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 26, 2003 | 06:44 AM
str8edgexx's Avatar
str8edgexx
its not that hard once you get the hang of it....although, I must admit, the first time I did it when I wasn't 100% sure of what I was doing, it was a total pain in the ass.
Old Sep 26, 2003 | 06:08 PM
Dupes's Avatar
Dupes
The idea of putting the seat down and going through the trunk to pop all the lil plastic snaps worked the best...i faced a lil trouble when i started becuase i realized my car has seat harness additions on the back pannel so first i had to remove them. After i got all three of them out i was able to put the seats down, open the trunk and just lye on my back, then i started pushing the white snaps through and POP it was off...Be Careful though of the brake light wires...you need to unhook them before you can fully remove the piece....
Dupes
