b16 wiring help
Old Sep 22, 2003 | 02:38 PM
civic-style's Avatar
civic-style
Default b16 wiring help
i have a 95 civic dx manual. I am putting in a b16 SiR II engine in it. I want to know what where and how I have to install the wires needed to complete the set up. Also if the harness is on the opposite side how do i extend all the wires.
Old Sep 22, 2003 | 03:39 PM
snatch's Avatar
snatch
best bet is to wire it your self thats what im doing, time consuming and tedeious but not hard just get the diagram
Old Sep 23, 2003 | 06:23 AM
Paul's Avatar
Paul
Eater of Rice
i went to a junk yard and just started cutting wiring harnesses off of civics and accords that plugged into the motor harness and the chassi harness then connected the wires and plugged it in. then i searched for MONTHS trying to find a gsr harness so i wasnt using such a ghetto setup.
Old Sep 23, 2003 | 11:08 AM
dantastic's Avatar
dantastic
cx power!
i used my stock CX harness to wire the engine. then i got the plugs for the vtec solenoid and pressure switch, and wired them thru a hole in the firewall (near the bottom of the battery) to the ecu. that's how you wire vtec.
Old Sep 23, 2003 | 03:31 PM
PHiZ's Avatar
PHiZ
BOOST GOD
or if you want a little cleaner, get a civic ex harness. The SIRII is OBD1, right?
-PHiZ
