my corner lights don't turn on
the turn on if I put on the turn signal, but when I turn on the headlights, they don't come on...
i blew the dashboard and tail light fuse... under the dash.. and replaced it but both fronts won't turn on.... any ideas? the bulbs work i'm sure. |
Re: my corner lights don't turn on
Originally posted by derf the turn on if I put on the turn signal, but when I turn on the headlights, they don't come on... i blew the dashboard and tail light fuse... under the dash.. and replaced it but both fronts won't turn on.... any ideas? the bulbs work i'm sure. |
bulb burnt out (the lower filament)? :dunno:
i repalced them....
the way it happened was when I got into my car accident I destroyed both halo lights. SO. i was trying to un splice the halo light wires from my constant and grnd. well they accidently touched (stupid me) and then from what I thought it just tripped the fuse. i replaced the fuse but the lights still won't turn back on... before the dash, rear lights, and front corners would not turn on when in "park"... now the dash and rear lights turn on but not the corner lights. |
Are all 3 wires still attached to your corner lights? I believe the red wire is the wire that keeps the corner lights on with the headlights, and the green wire makes them blink. Check where the splices were on the red wires to make sure they are still conected everywhere.
What did you splice with? Wire taps or did you actually cut the wires and splice them with 2 wires comming out of one? Why were you un-splicing wires with your battery still connected? |
i wasn't thinking about it, and I was kinda in a rush to just replace the bulb.
| All times are GMT -8. The time now is 11:20 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
