Stock fuel pressure
Old Aug 15, 2003 | 04:23 PM
civicexstacy00's Avatar
civicexstacy00
Default Stock fuel pressure
Anyone know the stock fuel pressure on a D16Y8?
Also what are the typical voltage outputs for the MAP sensor?
Old Aug 15, 2003 | 06:26 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
as far as fuel pressure its 28-36# with the hose off the FPR it should be 38-46#
map sensor is 5 volts.
Old Aug 15, 2003 | 10:56 PM
fook's Avatar
fook
Boosted D Series
so are you saying hypothetically you can remove the vacuum line on the FPR and instantly make your fuel pressure increase?
Old Aug 16, 2003 | 03:21 AM
NeverBX's Avatar
NeverBX
the removing of the hose is only for testing the fuel pressure if its as accurate as it can be. straight from my helms.
Old Aug 16, 2003 | 07:46 AM
oc_civic's Avatar
oc_civic
mcc racing
those numbers are about right i LOVE my in car fuel pressure gauge = )
Old Aug 16, 2003 | 09:34 AM
qtiger's Avatar
qtiger
Electrical I hope.
Old Aug 16, 2003 | 09:43 AM
oc_civic's Avatar
oc_civic
mcc racing
Originally posted by qtiger
Electrical I hope.
mecahincal WITH isolator.. as long as the isolator is not mounted on the fire wall it passes tech...
dunno if you are familiar with it.. but there is braided line from pressure source (fuel filter).. to huge brass isolator.. to braided line with presurized water/antifreeze mix to gauge.. so IF something happens.. no gas goes everywhere.. much cheaper than electric... and ive HEARD SLIGHTLY more accurate..
