Sway Bars ? - Need fast answer
Old Jul 22, 2003 | 06:49 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default Sway Bars ? - Need fast answer
I searched but couldn't find exactly what I need and I need a quick answer.
Will 99-01 GSR sway bars fit a '95 Civic DX sedan? If not, what would I need to do to get them to fit? Get EX lower control arms?
Thanks!
Old Jul 22, 2003 | 09:35 AM
wilsel's Avatar
wilsel
Depends, do you already have a rear sway bar?
If not you will need rear integra LCA's. Also, if you are a getting just the rear bar, you will need all the hardware to put it on. Front should be the same suspension as the teg. I'm not sure if the dx comes with a front sway bar or not, so you might need that hardware too. Otherwise you will just need the larger swaybar bushings.
Old Jul 22, 2003 | 09:51 AM
agent87's Avatar
agent87
Need zzzzz's
Just like wilsel said, you'll need:
-the bars
-the LCAs (for the front you might be able to get away with just obtaining that section)
-the endlinks
-the brackets and bushings
-the bolts
Old Jul 22, 2003 | 10:01 AM
westcoaststyle
DX has no stock sway bars.
Old Jul 22, 2003 | 10:24 AM
CivicRacr's Avatar
CivicRacr
i got the stock rear LCAs from a 99 integra with endlinks, PM me if interested.
Old Jul 22, 2003 | 11:25 AM
wilsel's Avatar
wilsel
I wanted an ITR rear sway. I'm starting to re-think the whole idea. For what I've spent (still need the d brackets), I could of gotten the ST rear sway/tie bar combo, and probably still saved some money.
Old Jul 22, 2003 | 11:57 AM
westcoaststyle
Ya, I've decided against the GSR bars. I'll go S/T before I get those others... just too expensive to try to piece together.
Old Jul 22, 2003 | 12:02 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
are the s/t adjustable?
does anyone make adjustable endlinks?
Project EVA - The Track Package
Project EVA
Old Jul 22, 2003 | 12:24 PM
agent87's Avatar
agent87
Need zzzzz's
I've seen adjustable endlinks but they used heim joints or whatever they're called which aren't ideal for street use because of dirt and grit. I'm sure they've talked about it on HT a few times in the competition forum.
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
ha ha. i like me ex with stock front and rear sway bars. should make upgrading easy. :goodjob:
