92 Si won't start when hot
Old Jul 10, 2002 | 03:22 AM
jenielsen's Avatar
jenielsen
Default 92 Si won't start when hot
This may not be the right forum but I'll give this a try...
I have a 92 Civic Si. It's been well maintained but in the last several weeks, on 3 occasions I've not been able to start the car. It turns over but will not fire. Once it was after the car had been driven (~5 around town miles) and the other two after sitting outside all day in parking lot. All three times the car eventually started after sitting for 10 mintues or so.
Is this a spark problem, fuel pickup problem, injectors? Any help is appreciated as I'm not much in the market for a new car nor do I like sitting in the parking lot after work waiting for the car to cool off.
Thanks.
Old Jul 10, 2002 | 06:22 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
How many miles are on the car, and what has been replaces so far.
around 80-100k you should have done regular maintance to include stuff like new plugs, wires, dist cap, timing belt and water pump, and a visual inspection of stuff like CV boots and joints and stuff like that
When was the last time you put a bottle of fuel injector cleaner in your fuel tank? You should do it every time you change your oil, every 3000 miles. This will prevent them from getting all clogged and dirty.
if you havn't done any of these maintanance items, then it could be anything you mentioned, or others.
I'm going to copy this to the engine tech forum, so look for it there.
Old Jul 10, 2002 | 06:51 AM
crucial Si's Avatar
crucial Si
Banned
take out the dis. and check the dis coil and let us know what the spring looks like...
Old Jul 16, 2002 | 09:40 PM
EG6's Avatar
EG6
PGMFI switch..... or bad ignitor
Old Jul 17, 2002 | 11:32 AM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
you might want to check out your fuses cause thats happened to my mom before
Geoffrey
92+ Civic/EL & Del Sol
4
Mar 9, 2008 04:06 PM
highwayman32
Engine Swaps, Tech & Tuning
8
Oct 15, 2007 05:05 PM
mitoppo
Legend, RL, & RLX
Nov 14, 2003 01:06 PM
jenielsen
10
Sep 2, 2002 07:43 PM
highwayman32
CRX & Pre 92 Civic
6
Jul 3, 2002 02:49 AM
