When removing stock head unit on 98 ex how do i keep dome lights active?
i already searched but couldnt find a good answer. ive got a 98 ex, when i remove the head unit what wires do i need to connect together to keep the dome lights active (diagram?). i dont need to worry about keyless entry because i have a viper alarm.
thanx
thanx
you need to find the green wiring harness (the one that you didn't plug into your new headunit) In that harness, you will find a green wire with a red stripe and a green wire with a black stripe. If you connect those two wires together with a t-tap, or just splice them together, it will make your dome light work again.
