B20???
Old Jun 13, 2003 | 02:51 PM
BrainFearGone's Avatar
BrainFearGone
Default B20???
im lookin into swaps and want some info on this setup...i dont know what kind of power a b20 can put out...ive heard of them with gsr heads with good power...can someone give me some infor on this motor or refer me to a site or somthing...thanks...oh and is this practical for a 5thgen hatch?
Old Jun 13, 2003 | 02:57 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
run a search,...a b20 with a vtec head does put down pretty good numbers and the b20 has nice torque but reliability is an issue,...i have a non vtec b20 but im gonna boost mine,..im not gonna go the vtec route because i went that way with my LS motor already
Old Jun 13, 2003 | 04:06 PM
BrainFearGone
how much was your setup...and also what trans did u use...i havent found a place that does a complete swap with the b20...well prolly cause of trans issues...but i think i want to put a gsr head on it and see how it goes. But i have to research cause i dont want to blow it...thanks a lot tho
Old Jun 14, 2003 | 01:42 PM
i want a civic's Avatar
i want a civic
Search for CRVTEC or LSvtec, you'll find some info.
Old Jun 14, 2003 | 03:55 PM
Kai's Avatar
Kai
Rotorphile.
Default Re: B20???
The engine acts like a B18A/B "LS" motor with a little more torque. It is the same engine with a slightly bigger bore.
A B20 with a P72 "GS-R" head acts like a B18C1 "GS-R" engine but with more torque, once again due to the higher displacement. Do not even consider this hybrid until you do a LOT of research and have a lot of cash to pour into building it., because an improperly built "CRVTEC" hybrid will do all sorts of bad things if you don't build it right (valve/piston contact, rod breakage, oil leakage, etc)
It is very practical for a 5G hatch, it has been done many, many times before.
