vtec + turbo
i recently installed a 15g turbo on my ex coupe, and im not sure if vtec is kicking in. is there some kind of distinct sound i should be listening for??? before it always seemed to scream when vtec kicked in. now it just kinda sounds like the turbo spools, but no distinct sound.
hmm.. i'd post in engine tech as well if you havent
Do you really need vtec with boost?
Originally posted by SpeedRacerEX-R Do you really need vtec with boost? VTEC isn't really felt on the SOHC engines anyways. yellowcivicex, Have you tuned your setup? |
you dont need vtec when your boosting...
Originally posted by Cashis EG8 VTEC isn't really felt on the SOHC engines anyways. yellowcivicex, Have you tuned your setup? |
haha...haven't had it on a dyno yet. i guess that's my next thing to do. b4 i could feel vtec kick in. the car wouldn't go anywhere without it. i guess it's not that important when boosting anyways.
VTEC is hardly noticeable to most on SOHC vehicles, also VTEC is oil pressure sensitive. Your new blow dryer, it is lubricated by oil, the same oil that is used in your crankcase, which engages (or as you like to call it "kick in") VTEC. My suggestion to you, check your oil
