b20z w/vtec
Old May 16, 2003 | 04:45 PM
muhphuggah's Avatar
muhphuggah
Banned
Default b20z w/vtec
Hey I found a guy that will trade me a b20z block for some old parts I have. If I get it I'm going to put the b16a2 head on it. Now I know the b20 wasn't built for high reving vtec. The guy owns a shop in Maryland called EVOLUTION MOTORSPORTS and he said that the only failing point on this swap would be the head bolts which he woul replace with ARP.
What are some disadvantages to this swap?
Do you know anyone that has had problems?
Old May 16, 2003 | 05:22 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
you need to replace the B20 pistons for pistons with bigger valve reliefs. B16 valves have been known to hit the B20 pistons, VERY BAD. If you're gonna be asking 8200rpm from the B20 bottom end, you might want new rods too.
Old May 17, 2003 | 06:26 PM
spooncivicb16b's Avatar
spooncivicb16b
also you might want to look into an lsd to help with the added torque
Old May 19, 2003 | 06:57 AM
xsists's Avatar
xsists
what pistons would you recomend? Im looking into this swap as well... would teg type r pistons be good or what pistons?
Old May 19, 2003 | 07:07 AM
Realm730's Avatar
Realm730
Check out this site http://www.b20vtec.com nothing too special but they have parts lists for a b20 build up
Old May 19, 2003 | 04:45 PM
Snoopy's Avatar
Snoopy
been there done that
itr pistons will not fit in a B20 block for obvious reasons.
Old May 20, 2003 | 07:42 AM
white_n_slow
it's my D in a B
you'll need 84mm pistons with big valve reliefs. Plenty of aftermarket options.
Old May 20, 2003 | 07:49 AM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
custom SRP pistons IMO - that's a lot of rod and piston weight to move at 8200 rpm!
Old May 20, 2003 | 07:55 AM
white_n_slow
it's my D in a B
....hence:
really, to do it right, you'll need to do the whole bottom end... to do it OK, you'll need at least rods and pistons... to do it crappy, all you need is pistons (some peeps even do it without pistons, but high RPM = valvetrain death)
