hood release cable
Old Jan 26, 2011 | 05:36 PM
montesa's Avatar
montesa
Default hood release cable
99 civic dx hood release cable platic handle broke. this looks like a real "fun" job to replace cable. any advice? please help...... thank you
Old Jan 31, 2011 | 11:21 AM
Redline96LX's Avatar
Redline96LX
Its not too hard. You will need to replace it of course, but It doesn't bolt to the plastic part, its removable. You remove the lower plastic piece, its got plastic snaps into the body of the car, and it yanks out. To get the B pillar piece out, that yanks UP, toward the upper seat belt pivot. Then you can remove the whole plastic piece. It should be self explanitory, but I'm guessing you'll want a 10 and 12mm socket with an extension.
Old Feb 2, 2011 | 04:28 PM
montesa's Avatar
montesa
I did a sort of 'cob job"fix. I stripped off the remaining plastic off the square shaft where the pull handle was. I found a pull knob with a set screw that fit the shaft. I also had to cut some of the kick panel to fit around the knob,but it really didn't look bad. much easierand faster than replacing the hole cable!!
