Integra Rotors on a Civic??
Old May 6, 2003 | 01:21 PM
riding low's Avatar
riding low
Default Integra Rotors on a Civic??
Wanting larger rotors on my civic...
is it possible to use Integra rotorrrrrrrrrrs??
possible stupid question alert
Old May 6, 2003 | 01:23 PM
The Beav's Avatar
The Beav
i
i think so, but why not just buy some aftermarket rotors then?
Old May 6, 2003 | 01:26 PM
riding low's Avatar
riding low
well yeah, but then they will still be the same oem size won't they?
Old May 6, 2003 | 01:29 PM
The Beav's Avatar
The Beav
i
some aftermarket are the same size some aren't just look around
Old May 6, 2003 | 01:44 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
What car do you have?
Old May 6, 2003 | 02:03 PM
riding low's Avatar
riding low
its a 2000 civic ex, other than aem big brake kit what are my options for larger front rotors?
Old May 6, 2003 | 02:28 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I don't know if the EX's front brakes are the same size as Si's... I don't think so, right?
Anyway, if you want to switch to Si or teg rotors, you'll need the whole knuckle with calipers, brake lines, rotors etc. You cant just switch to larger rotors without relocating you calipers, so just swapping everything takes care of it all. ....and no, you can't just relocate your calipers somehow... thats why you gotta swap.
Old Nov 11, 2004 | 10:53 PM
Redline96LX's Avatar
Redline96LX
Default Brakes
No. If you have a 99 Civic EX, you use the 10.4" rotors. The Si has the same rotors, and 94-01 Integras (not R) have the same EXACT rotors. Upgrading requires new calipers for new rotors. The cheap way to do it, is get ITR calipers (92 Honda Accord Wagon uses the same caliper, just cheaper and easier to find). Then get 92-96 Prelude VTEC rotors redrilled to the 4x100 bolt pattern. This should go onto your stock knuckle. SOmeone verify this. If not, a Si knuckle or a 94-01 Integra LS knuckle will work.
One more note, you have to use 99-00 Si brake lines. and no, Integra ones wont work.
Old Nov 12, 2004 | 01:42 PM
white_n_slow
it's my D in a B
thank you for reviving an 18 month old thread
