Chek Engine Light :(
Old Apr 29, 2003 | 01:08 AM
Kabooki's Avatar
Kabooki
Default Chek Engine Light :(
is there a simple way to get the error code out of my 93 honda?
on my isuzu i could put a paper clip in it and make the dash blink a error code.
I just had a motor installed(used) and after driving around 20-30min i get a check engine light. Some have told me its most likely the o2 sensor. but they are like 69$ and without a job, I need to know what the real prollem is before i spend.
Old Apr 29, 2003 | 01:58 AM
vtecfed's Avatar
vtecfed
RIP VTECFED
http://www.teirney.net/civic/ECUErrorCodes.htm
There is a TWO wire BLUE connector under your dash right beside the computer. If you dont know were the computer is its on the passenger side by the feet on the right side. good luck
Old Apr 29, 2003 | 02:12 AM
vtecfed's Avatar
vtecfed
RIP VTECFED
http://www.profxtech.com/illuzion/ecucodes.htm
sorry wrong generation.
but ya you do the same paperclip trick you used on the other car. good luck
Old Apr 29, 2003 | 10:35 PM
Kabooki's Avatar
Kabooki
so i just short the 2 connectors?
Old Apr 29, 2003 | 10:43 PM
Kabooki's Avatar
Kabooki
YAY! i shorted them and got my error code, looks like 1 long and 7 short, im not quite sure what that means though, if i referenced the chart right, its my fuel injection system?
Old Apr 29, 2003 | 11:02 PM
Kabooki's Avatar
Kabooki
I FREAKIN FIGURED IT OUT!!! thanx alot! its the freekin Vehichle Speed Sensor! that explains both prollems so now i just gotta figure out what the hell that is and where
Old Apr 30, 2003 | 05:48 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
It's on the tranny, near the back, but still on the top. 3 wire plug on it. If you need one for a D series engine, let me know. I can hook you up!
