radiator?
Old Apr 15, 2003 | 06:08 AM
BlackSol's Avatar
BlackSol
Default radiator?
I was wondering if the del sol radiator is enough to cool a b18c5. If not will an integra radiator fit in the del sol, or what do i need to buy?
Old Apr 15, 2003 | 09:43 AM
sol_guy02's Avatar
sol_guy02
i'm pretty sure that the one you have should work unless there is a difference between the s, si, and b16 radiators. i've heard of people using the same radiator for just about any b series engine, but i don't know if there is a difference between d series and b series radiators in the sol. hope that helps in some way.
Old Apr 15, 2003 | 10:36 AM
Soltaker's Avatar
Soltaker
I'm a bad, bad man.
I kept the stock radiator from my D16Z when I did my B18C swap. Temps never changed.
Old Apr 16, 2003 | 12:54 PM
OSX2000's Avatar
OSX2000
Do what must be done.
Your existing radiator will work fine.
Old Apr 17, 2003 | 04:01 PM
vtecsol's Avatar
vtecsol
i think the only difference is that the b series rad is double stacked to save room for ac etc withe the bigger moter.. the d series is a single stack..they provide the same coolent because they are really the same size
Old Apr 17, 2003 | 10:35 PM
OSX2000's Avatar
OSX2000
Quite correct. In other words, your existing radiator will work fine.
