question jdm Gsr motor in 94 civic
Old Apr 10, 2003 | 12:29 PM
Kenny's Avatar
Kenny
Default question jdm Gsr motor in 94 civic
What else would i need other than the engine trans and ecu ? would i need to put the jdm gsr motor in my 94 civic ex couple ??
axles shift linkage mounts ??? thanks for the help !!!!!
and what kind of mounts ??
Kenny
Old Apr 10, 2003 | 12:47 PM
4-banging's Avatar
4-banging
Default Re: question jdm Gsr motor in 94 civic
Kenny
yeap, hopefully that tranny comes with factory lsd :naughty:
Old Apr 10, 2003 | 01:28 PM
dantastic's Avatar
dantastic
cx power!
the oem mounts on the b18 should be fine, as long as ur car is manual also. u should also pick up all the maintenance items, ie. t-belt, water pump, tensioner etc and change them while the motor is out of the car
Old Apr 10, 2003 | 02:19 PM
Kenny's Avatar
Kenny
Thanks a million guys !!!
Old Apr 10, 2003 | 05:39 PM
fish's Avatar
fish
remember a jdm motor is set up for right hand drive so the engine harness doesnt hook up to the chassi harness. you have to either buy a harness to extend it (hasport maybe) or do a junk yard set up like i did on my jdm b16
Old Apr 10, 2003 | 06:16 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
Fish is correct. A JDM engine is RHD so the battery/fuse box and ECU's are on the opposite side of the car so the stock JDM wiring harness on the motor is useless except to salvage plugs and wires. You can remove your old D-series harness and modify it to work (how depends on what model Civic you have).
You will also need the items you listed, B-series axles (there are 3 pieces), B-series shift linkage (D-series will not work) and there are several mounts you will need. You need the big silver mount top engine mount (coming out of the timing cover). You will also need the lower engine and tranny brackets. You can re-use the Civic rubber mounts on the bottom of the frame rails. You can re-use your Civic mount on top of the tranny. For the rear, you need the B-series T bracket and re-use the Civic rubber mount on top of the rear subframe. You'll also need a GS-R throttle cable and make sure you also replace all the belts and radiator hoses (cheap insurance). Good luck with your swap. Seeya.
Old Apr 10, 2003 | 07:59 PM
dantastic's Avatar
dantastic
cx power!
i would use the stock civic harness, add the knock sensor and secondary intake runner solenoid wires
Old Apr 10, 2003 | 08:44 PM
fish's Avatar
fish
if you use the stock harness you may need to wire the o2 sensor as well depending on the # of wires running off of it. wire vtec and knock sensor as well like you said
Old Apr 11, 2003 | 08:59 AM
dantastic's Avatar
dantastic
cx power!
haha... i forgot. i actually did that on my swap. i put a b16 in my car, used the stock cx harness, added the vtec switch, oil press sensor, and made an extention for the o2. i didnt wire the knock sensor since im running a chipper p28
Old Apr 12, 2003 | 02:05 PM
Kenny's Avatar
Kenny
Thanks alot for the help guys !!! you are all the shiznitz !!
