Stereo Help
Old Apr 2, 2003 | 07:52 PM
RED90crxsi's Avatar
RED90crxsi
Default Stereo Help
Ok, I got my Del Sol about 2 years ago and it had an aftermarket stereo in it and well I decided to upgrade it and I got it all out and well it is missing the bracket that holds the stereo in the cubby hole. I found that the previous stereo was being held in place by a peice of double sided sticky foam pad. Now I am trying to locate the proper bracket for my sol so I can do the stereo right. Any suggestions or even a part #?
Thanks for any help
Trav
Old Apr 3, 2003 | 04:17 AM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
You might want to try a junkyard... I'm sure they'll charge next to nothing for such a small part.
Old Apr 3, 2003 | 12:01 PM
RED90crxsi's Avatar
RED90crxsi
I have tried all junkyards within 75 miles of where I live and no success
Old Apr 3, 2003 | 02:14 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
www.hondaautomotiveparts.com is the site for majestic honda. Might be a little pricey, but they should have it...
Found it.... Took me a while, so I figured I'd help!
http://www.hondaautomotiveparts.com/...STRUMENT+PANEL
Old Apr 4, 2003 | 06:20 AM
97HONDASOL's Avatar
97HONDASOL
you new head unit should have the benzi box to hold the unit in.
Old Apr 4, 2003 | 08:40 AM
RED90crxsi's Avatar
RED90crxsi
Your Right, and I do have that but I need the frame/bracket to put that into.
Thanks Bakeoff, You Da Man!!!
Old Apr 7, 2003 | 04:59 AM
97HONDASOL's Avatar
97HONDASOL
maybe mine is different. I used the push tabs on the benzi. to lock it to my console. If you do need something to hold it in. contact honda and get a part number. then it will be easier to find
Old Apr 19, 2003 | 04:04 AM
clm-Sol's Avatar
clm-Sol
If you're talking about the metal brace that the head unit sits on, it's not a required piece, but it does add more rigidness to the mounting.
