problem starting car
Old Mar 23, 2003 | 05:36 PM
azncivicboi's Avatar
azncivicboi
Default problem starting car
i got a problem with starting my car. When i turn the key my starter doesn't crank sometimes. I have to sit there for hella minutes turning the key over and over before it'll start cranking. Anyone know where the bad connection could be?
Old Mar 23, 2003 | 06:37 PM
jenkinsisme's Avatar
jenkinsisme
Be more specific. Does it spin over? If so, it's most likely the Main Relay. Possibly the distributor.
Old Mar 23, 2003 | 08:02 PM
azncivicboi
it makes like a hmm sound, sometimes it'll start cranking for half a sec then make the hmm sound
Old Mar 23, 2003 | 08:33 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
sounds like either a fuel pump problem, but more likely that your main relay is going out... Does it do it more when it's warm out?
Old Mar 23, 2003 | 08:52 PM
Hondaman's Avatar
Hondaman
Black Pearl
Try cleaning your battery posts and cable ends, it sounds like they are getting dirty and losing contact. Put a bit of grease on the posts before you put the cables back on, this will help to prevent corrosion in the future and give you good electrical contact.
