When lowering, what blows stock shocks?
Old Mar 21, 2003 | 08:16 AM
T-RO's Avatar
T-RO
Default When lowering, what blows stock shocks?
If you lower your car using springs or a coilover setup but keep your stock shocks. What exactly causes the stress that could blow your shocks? Is it the lowered height? Or is it the stiffer spring rate?
By the way, does anyone know the stock spring rate on a 94 Civic EX?
Thanks everyone.
Old Mar 21, 2003 | 08:46 AM
hybridhondahatch's Avatar
hybridhondahatch
for that added pep
its just because the stress when the shocks are awalys compressed
Old Mar 21, 2003 | 09:09 AM
Nelson's Avatar
Nelson
Administrator
Stock springs are softer... aftermarket lowering springs are very hard.
Stock shocks/struts were designed for the stock softer spings.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 21, 2003 | 01:09 PM
FromTheBottom's Avatar
FromTheBottom
Driver of Trains
Lowering springs put more force on the shocks because they are now more compressed under the same weight. This compression makes inner pressure greater causing fatigue failure.
Old Mar 21, 2003 | 01:18 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Crucial mentioned something about sometimes you can accidentally blow the shocks by not installing the springs right.
Old Mar 21, 2003 | 01:49 PM
crucial Si's Avatar
crucial Si
Banned
indeed.
Old Mar 21, 2003 | 03:44 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Actually an aftermarket spring makes the shock work harder not because your car is compressing the shock more, but because since the spring is stiffer it compresses and rebounds the shocks more often hence making the shock work MORE than a softer OEM spring.
Autocross Help Page
Old Mar 21, 2003 | 08:16 PM
CXHatchback's Avatar
CXHatchback
well obviously it's both. The constant pressure the shock is under, and the inability of the stock shock to keep up with the higher spring rates.
Old Mar 22, 2003 | 09:33 AM
CivicSiRacer
Well actually making the shock work harder will make the oil or gases in the shock overcook/boil in some instances. Which is why when you blow a shock the oil or gases start to leak out of the seals cause the seals were not meant to take that much abuse.
Wish I kept that website about what goes on in a shock.
Autocross Help Page
Old Mar 23, 2003 | 02:33 AM
agent87's Avatar
agent87
Need zzzzz's
In addition to the already stated fact that the shocks would have to attempt to slow down greater forces, I thought I'd also add the obvious... If you go too low, the shock can bottom out causing internal damage.
