Installing Skunk2 rear lower tie bar.....
Old Feb 28, 2003 | 03:53 PM
VSM Si's Avatar
VSM Si
Default Installing Skunk2 rear lower tie bar.....
Any tricks to it, or just simple unscrew-screw and all done?
Does any1 have any pictures or step-by-step help?
Old Feb 28, 2003 | 04:39 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
oh yea, I did it.
Not really just a screw/unscrew but it is at the same time.
no step by step sorry
its not too hard, make sure you have all the OEM stock hardware. I actually have teg one on my car(teg rear LCA's). Which one are you getting?
its fairly straight forward, if you need I can try and get some picks of my setup to show you what it looks like
Old Mar 13, 2003 | 09:23 AM
IamThFEAR's Avatar
IamThFEAR
From experience, dont get frustrasted when one side takes 5 seconds and the other takes 30 minutes. My shop had to lower the lift and then jack up the tire on the side we could'nt get to line up correctly. But all in all pretty simple mod, looks nice too
Old Mar 13, 2003 | 10:00 AM
wilsel's Avatar
wilsel
Mine only took 30 mins to install.:dunno:
It's only two bolts. The only problem you may have is getting the bolts back in, you might have to put move the LCA's around to get the holes lined up again. Should be pretty straight forward.
Old Mar 13, 2003 | 11:51 AM
4-banging's Avatar
4-banging
Default Re: Installing Skunk2 rear lower tie bar.....
my dc-sports was just a unscrew...put bar on....screw...fairly simple DIY'er
Old Mar 13, 2003 | 11:59 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
it's very simple...
1) put car on jack stands...
2) remove wheels
3) remove the two bolts...
4) put in the lower tie bar (do one side at a time.)
5) before putting the new bolts in... spray the hole from both sides with silicon spray.. then use grease and rub it evenly on the bolt.
6) use a rubber mallet and tap that a$$ in... this will align itself.
7) if step six doesn't work... then use a small hydrolic jack to jack up the arm, just to align it... and then continue to tap it.
8) tighten it to spec, and use a torque wrench.
9) after it is done then put wheel back on and lower the car... and ur done... plus no squeeking... hehe :thumbup:
Old Mar 13, 2003 | 12:04 PM
VSM Si's Avatar
VSM Si
Ok one question though
when i got it i see 2 bolts a lower tie bar, and plus 4 metal looking things, what r they for? The way i figure it;s becuz they bolt is too long?
Old Mar 13, 2003 | 12:54 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
dood u gotta be more specific on the 4 metal thingy... r u refering to the washers??? or??? better yet... use a digicam and take snap shots of it.
Old Mar 14, 2003 | 03:28 AM
wilsel's Avatar
wilsel
Those 4 metal things go into the holes (bearings) on the strut bar.
Old Mar 14, 2003 | 04:33 PM
VSM Si's Avatar
VSM Si
Thanx guys!!!:thumbup:
