Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   92+ Civic/EL & Del Sol (https://www.honda-acura.net/forums/92-civic-el-and-del-sol-6/)
-   -   What's your opinion? (https://www.honda-acura.net/forums/92-civic-el-and-del-sol/52876-whats-your-opinion.html)
Fast Bug Feb 26, 2003 12:18 PM
Originally posted by Jeice
The 95 civic EX has DC header, 2.25 inch exhaust with a ghey muffler, and an AEM cold air intake.
The 00 Si has DC header, Apex WS full catback exhaust, AEM cold air intake..
Same mods... EX runs faster.
How is this not a correct statement?
Originally posted by Fast Bug
So, very similar mods on both cars and the ex still runs faster huh? I have to beg to differ assuming both drivers are equally competent, stick, and the run is from 0-80 mph.
Please note that my judgement is based on logical facts and not because I have 2 SI's.
On Street tires, The EX Ran 10.27@70 in the 1/8 mile
The Si ran a 10.29@70.
This is their BEST E/t's. Both of them are good drivers. But I think traction is their main problems.
Each time they switched cars to get better times it resulted in a worse time.
On the street, with the SI dropping into 2nd gear first, the EX stays dead even with the SI, then Pulls away in third gear. SI's are geared very short.
I transfer this interesting discussion from kill stories to civic forum to get everyone's input. Shoot away... :)
preylude99 Feb 26, 2003 12:29 PM
well on the street it could be a toss-up, many factors apply. But on the track something has to be up for the ex to beat out the Si with generally the same mods and supposedely equal drivers. 0-40 it might be even cause the SI doesnt have much more torque, but after that the vtec should do the rest of the work and the SI should be faster, is the SI getting a bad launch or what?
airon Feb 26, 2003 12:34 PM
could happen as it looks like its a 1/8th track
the si, also known to many as the torqueless wonder, does not make its horsepower to well into the rpms, it makes 160 hp at 7600 rpm
with a bad launch a b16 takes a while to get up to speed
also at 70 mph the si's gearing means its in 3rd gear
with the ex cant it still be in 70, or is the gearing shorter?
JDMB16EJ1 Feb 26, 2003 12:58 PM
I think that IF it's true, which I'm kind of doubting, the driver of the SI can't drive very well even though he says he can
Fast Bug Feb 26, 2003 01:04 PM
I'm also curious to find out how much each driver weighs...
If the SI driver weighs 250 lbs vs. EX driver at 150 lbs, I won't doubt the EX will finish slightly ahead...
sokencivic Feb 26, 2003 02:51 PM
its a possibility
same conclusion when you add a turbo to a type R and a GSR. the gsr is faster
19.3secS2K Feb 26, 2003 02:56 PM
wouldn't the eg ex be lighter, therefor easier to keep up with the slightly overwieght si?
txhatch Feb 26, 2003 03:03 PM
Thats all driver, the b16 should have a definite advantage over d16.
Jkan2001 Feb 26, 2003 05:11 PM
makes perfect sense...i used to keep up with i/h/e si's when i was i/h/e in my 00 ex but when they hit middle of 3rd around 70 they'd start walking pretty hard, same with the GSRs. The 1/8 mile tracks are mostly about the launch.
Fast Bug Feb 27, 2003 07:36 AM
I agree... And I have to add that shift point is equally important.
© 2026 MH Sub I, LLC dba Internet Brands
