Revs itself while idling
Old Nov 1, 2009 | 11:52 PM
Nuget's Avatar
Nuget
Default Revs itself while idling
Hey Guys, Ive got a 92 JDM Delsol and yesterday I just noticed a strange problem that had never happened before. During idling (2k rev) it drops to a normal 1k rev then after like 1-2 seconds the car seems to rev it self with my foot off the pedal?
Has anyone had these problems? Will this be a major issue and how could I fix this?
Thanks in advance
Old Nov 2, 2009 | 04:12 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Sounds like the problem I had. Fast Idle Valve needs replaced.
Autocross Help Page
Old Nov 2, 2009 | 05:53 AM
Line7's Avatar
Line7
Platinum Member
also make sure you got coolant in the radiator.
Old Nov 18, 2009 | 12:18 PM
Redline96LX's Avatar
Redline96LX
Check the throttle and IACV, physically. It scould be something sticking, like the IACV. it can get dirt and shit in it over the years, its not hard to take off, and can be cleaned sometimes with a spray called "deep creep" which is like a draino chemical for cars, it cleans out stuff by dissolving crud and oil and that. also carb cleaner can be sprayed into the throttle body which could also get stuff on it and stick. this can happen on cars as old as ours just by exposure to the road and dirt and dust and all. nothing big, but cleaning this sort of stuff every few years helps, though if you always keep a clean air filter, it may be in better shape, though the recirculation can add oil into it over time.
Old Nov 18, 2009 | 06:21 PM
jlu.built's Avatar
jlu.built
350whp NA!!
all these replies are correct..another thing you can look at if you did all these and still acting up is make sure the IACV is good.. It happen to my buddies car. After a whole day of changing shit we realized the plug was faulty( 1 of the pins were broken)
Old Nov 21, 2009 | 05:00 PM
Thrule01's Avatar
Thrule01
my del sol had the same issue...fast idle/high idle valve was bad...took it to a dealership and it was like 150 installed...
Old Nov 27, 2009 | 12:23 AM
Nuget's Avatar
Nuget
thanks guys! will check up on that :blue:
ur replies are much appreciated
Old Nov 27, 2009 | 07:48 AM
Civic2Scooby's Avatar
Civic2Scooby
take out the FITV and screw it back in.
